PIC32 XC32 - Bad Datasheet
AtomSoft
Hey im using the PIC32MX250F128D processor and noticed IFSx are switched:
extern volatile unsigned int        IFS0 __attribute__((section("sfrs")));
typedef union {
  struct {
    unsigned CTIF:1;
    unsigned CS0IF:1;
    unsigned CS1IF:1;
    unsigned INT0IF:1;
    unsigned T1IF:1;
    unsigned IC1EIF:1;
    unsigned IC1IF:1;
    unsigned OC1IF:1;
    unsigned INT1IF:1;
    unsigned T2IF:1;
    unsigned IC2EIF:1;
    unsigned IC2IF:1;
    unsigned OC2IF:1;
    unsigned INT2IF:1;
    unsigned T3IF:1;
    unsigned IC3EIF:1;
    unsigned IC3IF:1;
    unsigned OC3IF:1;
    unsigned INT3IF:1;
    unsigned T4IF:1;
    unsigned IC4EIF:1;
    unsigned IC4IF:1;
    unsigned OC4IF:1;
    unsigned INT4IF:1;
    unsigned T5IF:1;
    unsigned IC5EIF:1;
    unsigned IC5IF:1;
    unsigned OC5IF:1;
    unsigned AD1IF:1;
    unsigned FSCMIF:1;
    unsigned RTCCIF:1;
    unsigned FCEIF:1;
  struct {
    unsigned w:32;
} __IFS0bits_t;
extern volatile __IFS0bits_t IFS0bits __asm__ ("IFS0") __attribute__((section("sfrs")));
extern volatile unsigned int        IFS0CLR __attribute__((section("sfrs")));
extern volatile unsigned int        IFS0SET __attribute__((section("sfrs")));
extern volatile unsigned int        IFS0INV __attribute__((section("sfrs")));
extern volatile unsigned int        IFS1 __attribute__((section("sfrs")));
typedef union {
  struct {
    unsigned CMP1IF:1;
    unsigned CMP2IF:1;
    unsigned CMP3IF:1;
    unsigned USBIF:1;
    unsigned SPI1EIF:1;
    unsigned SPI1RXIF:1;
    unsigned SPI1TXIF:1;
    unsigned U1EIF:1;
    unsigned U1RXIF:1;
    unsigned U1TXIF:1;
    unsigned I2C1BIF:1;
    unsigned I2C1SIF:1;
    unsigned I2C1MIF:1;
    unsigned CNAIF:1;
    unsigned CNBIF:1;
    unsigned CNCIF:1;
    unsigned PMPIF:1;
    unsigned PMPEIF:1;
    unsigned SPI2EIF:1;
    unsigned SPI2RXIF:1;
    unsigned SPI2TXIF:1;
    unsigned U2EIF:1;
    unsigned U2RXIF:1;
    unsigned U2TXIF:1;
    unsigned I2C2BIF:1;
    unsigned I2C2SIF:1;
    unsigned I2C2MIF:1;
    unsigned CTMUIF:1;
    unsigned DMA0IF:1;
    unsigned DMA1IF:1;
    unsigned DMA2IF:1;
    unsigned DMA3IF:1;
  struct {
    unsigned w:32;
} __IFS1bits_t;
extern volatile __IFS1bits_t IFS1bits __asm__ ("IFS1") __attribute__((section("sfrs")));
extern volatile unsigned int        IFS1CLR __attribute__((section("sfrs")));
extern volatile unsigned int        IFS1SET __attribute__((section("sfrs")));
extern volatile unsigned int        IFS1INV __attribute__((section("sfrs")));
IFS0bits are supposed to be in IFS1 or at least thats what my datasheet states.
For instance : U1RXIF is in IFS1 when its supposed to be in IFS0
Or is this a DATASHEET MISTAKE?
Which is CORRECT?
How do i tell Microchip about this?
Why hasnt anyone else noticed this? (im sure im not the only guy using this MCU)
Im using XC32 1.31
I would suggest checking the errata page attached to the datasheet to make sure it's not an error there. I ran into that issue once with the ADCON register on the PIC18--the datasheet had everything inverted, and I think a couple of the bits mixed around. I checked the errata and there it was, corrected.
Unfortunately I have no experience with the PIC32, but hopefully this helps a bit.
Good luck,
Matt
Hmm. im sure its a XC32 error then. If no one really had this issue before and follow the datasheet with other compilers. Perhaps i should simply rename
IFS0bits ---> IFS1bits
and
IFS1bits ---> IFS0bits
Seems like that would fix it but am not sure. Dont want to ruin anything :)
.. Just noticed some bits are correct and some are not.. would have to rewrite it all as well just to make sure all bits match.. not hard work but something i shouldnt have to do :(
My Fix:
Replace lines 2775 to 2830
C:
typedef union {
  struct {
    unsigned CTIF:1;
    unsigned CS0IF:1;
    unsigned CS1IF:1;
    unsigned INT0IF:1;
    unsigned T1IF:1;
    //unsigned IC1EIF:1;
    unsigned IC1IF:1;
    unsigned OC1IF:1;
    unsigned INT1IF:1;
    unsigned T2IF:1;
    //unsigned IC2EIF:1;
    unsigned IC2IF:1;
    unsigned OC2IF:1;
    unsigned INT2IF:1;
    unsigned T3IF:1;
    //unsigned IC3EIF:1;
    unsigned IC3IF:1;
    unsigned OC3IF:1;
    unsigned INT3IF:1;
    unsigned T4IF:1;
    //unsigned IC4EIF:1;
    unsigned IC4IF:1;
    unsigned OC4IF:1;
    unsigned INT4IF:1;
    unsigned T5IF:1;
    //unsigned IC5EIF:1;
    unsigned IC5IF:1;
    unsigned OC5IF:1;
    //unsigned AD1IF:1;
    //unsigned FSCMIF:1;
    //unsigned RTCCIF:1;
    //unsigned FCEIF:1;
    //ATOMSOFT FIX BELOW
    unsigned SPI1EIF:1;
    unsigned U1EIF:1;
    unsigned U1RXIF:1;
    unsigned U1TXIF:1;
    unsigned I2C1BIF:1;
    unsigned I2C1SIF:1;
    unsigned I2C1MIF:1;
    //END OF FIX
  struct {
    unsigned w:32;
} __IFS0bits_t;
typedef union {
  struct {
    //AtomSoft Fix
    unsigned CNIF:1;
    unsigned AD1IF:1;
    unsigned PMPIF:1;
    unsigned CMP1IF:1;
    unsigned CMP2IF:1;
    unsigned SPI2EIF:1;
    unsigned U2EIF:1;
    unsigned U2RXIF:1;
    unsigned U2TXIF:1;
    unsigned I2C2BIF:1;
    unsigned I2C2SIF:1;
    unsigned I2C2MIF:1;
    unsigned FSCMIF:1;
    unsigned RTCCIF:1;
    unsigned DMA0IF:1;
    unsigned DMA1IF:1;
    unsigned DMA2IF:1;
    unsigned DMA3IF:1;
    unsigned USBIF:1;
    //unsigned CMP3IF:1;
    //unsigned SPI1EIF:1;
    //unsigned SPI1RXIF:1;
    //unsigned SPI1TXIF:1;
    //unsigned U1EIF:1;
    //unsigned U1RXIF:1;
    //unsigned U1TXIF:1;
    //unsigned I2C1BIF:1;
    //unsigned I2C1SIF:1;
    //unsigned I2C1MIF:1;
    //unsigned CNAIF:1;
    //unsigned CNBIF:1;
    //unsigned CNCIF:1;
    //unsigned PMPIF:1;
    //unsigned PMPEIF:1;
    //unsigned CTMUIF:1;
  struct {
    unsigned w:32;
} __IFS1bits_t;
C:
    //IFS1bits.U1RXIF = 0;  //BEFORE
    IFS0bits.U1RXIF = 0;    //AFTER
I guess i had some old documentation... hmm. google isnt your friend all the time... Got the newer version from Microchip and looks like it was correct. So was a datasheet flaw. Placing backup back :)
I've had that problem several times as well. When you get the datasheet for a PIC, it's critical that you get it directly from a link on the Microchip website. Usually the PDF that shows up directly on google has errors.
Glad you got it solved, Jason!
Matt
