PICC pointer to PORTs possible?
serj.t.s
Hi I've just beginned programming pics in C and I was trying to "merge" ports C and D together in one 16bit variable, does anyone have an idea on how can i do this?
Thank you
Why would you want to?.
You could certainly easily write a function that takes a 16 bit variable and place the top eight bits to one port, and the bottom to another. However, I don't do C, but it's easy in any thing else, so presumably will be in C?.
Hi Nigel, I just though it would be more efficient and simple because I'll be manipulating those registers together with shifts and other operations but I guess I'll have to do it yout way.
Thanks for the reply.
The direct answer is, you can if you compiler allows it.
When asking C questions please let us know what processor and compiler you are using. They differ enough that one needs to know.
I use CCS which has #bit and #byte directives that allow that sort of thing. But no #word. It may exist on 16 bit compilers.
A better, compiler independant, answer is along the line of what Nigel suggested. Declare a 16 bit shadow register (just a 16 bit variable) and do you crunching with it. When needed call a function to write the top 8 bits to C and the lower to D.
If you need speed make the copy function inline.
Hi, sorry about the lack of info.
I am using the PICC compiler from HI-Tec h.
And I ended up doing:
PORTC = temp;
PORTD = (temp >> 8) & 0xFF;
This compiler doesn't have BYTE(temp) or char(temp), but it worked this way. Btw I don't think the 0xFF mask is necessary. I guess I'll try it out tomorrow, i am soo lazy
