Piezo Ultrasonic transducer driver
brimsant
Hi guys
Can someone take a look at this schematic and see if there are any glaring issues with it? I'm pretty new to circuit design so most of what I have is from looking at the designs of other people.
Basically what I want to do is to program the PIC to read the temperature from the Thermistor and then driving a piezo ultrasonic transducer through Frequency Shift Keying to send the reading.
I am planning on using this transducer: https://abra-electronics.com/sensor...sor-16mm-1-pair-transmitter-and-receiver.html
Your thermistor is using the wrong pin.
According to the PIC Datasheet, pin 11 (RA2) is configurable as an analog input.
Looks like a reasonable choice to me.
So why is it the wrong pin?
Yes, RA2 looks fine - but another point, why use a crystal?, the PIC has a perfectly satisfactory internal oscillator which is accurate enough for driving a piezo.
However, I'm a bit puzzled about the use of the piezo transducers?, it seems a pretty strange and unreliable method of communication?, and requires fairly precise alignment.
