Play basic music from a pic
Mosaic
I want to build nursery rhyme play back from a PIC .
Single voice should be ok...kinda like the musical birthday cards etc.
Can anyone suggest an approach?
I was thinking of a frequency and duration pair of bytes for each tone so that a 256 byte eprom can 'store' up to 128 tones to make up clips of rhymes. Perhaps 10 seconds each?
Have a look here - it plays normal ringtones as used on phones:
I had a play with it a long time ago, it works really well - and is easily ported to a tiny 8 pin PIC (and would presumably fit in a SM 6 pin one?).
Just a quick update, as this thread 'inspired' me :D
I've started playing with XC8 recently, so took the opportunity to see if I could get this to work with XC8 (C never seems as portable as people like to suggest).
I already happened to have a 16F876 connected to my PICKit3, and the only change I had to make to the code was line 230, replacing OPTION with OPTION_REG (which I believe Ian mentions in the C versions of my tutorials?).
Worked straight away after that - biggest problem was finding a speaker to try on it :p
That's good news...
While I plan to learn PIC C this year...I am still an ASM guy.
But I can read the C structure.
That's good news...
So am I, but I'm trying to learn C (yet again!:D)
When I played with the ringtone circuit before, I converted the C to asm to run on a 12F675 - it's a long time back though, no idea where the code might be?.
However, having recently downloaded and installed the free version of XC8 it was EXTREMELY easy to get the C code from the site above to work - I've also changed it to work with the 12F1840 (because I have some :D) - and while I haven't finished altering the setup details for that chip it does still build OK (but I can't seem to find my 8 pin tutorial board?, so my enthusiasm has waned). But a small 8 pin chip that plays ringtones is pretty cool.
