Please help with reading Modulated IR OUTPUT
Picman99
Hi I'm using a 16F84A (when I'm not using a 16F628A) but thats beside the point. I am building a Hexapod and am trying to control direction using modulated (38khz) ir signal. Transmitter -->works FINE. Receiver should be high output shifting to low in IR presence. I was going to read its output with a PIC (PortB.4) and if high go to one routing if low goto another. The problem is that the low signal is around 1.8V so the pic is not registering a low and therefore not switching. Do I have to use the PORTA as comparator function??????????? Please help. By the way I am programming in high level basic and am not too up on assembly code!!!!!!!!!!!!!!!!!! Find Attached the IR Test Code.
  • irtester.txt
Try checking the IR circuit in the hardware section of my PIC tutorials, it's ABSOLUTELY VITAL! that you include the decoupling components shown, this could be your problem - I also like to use a pull-up resistor on the output, again this is shown on my circuit.
I presume you're running the transmitter LED at very low power?, and shielding it from the receiver?.
Ir Receiver
Thanks Nigel. Sorry I took so long to get back. I had decoupled but only with 1000 pics. Replaced with 47 micros and all seems well. I'm building up hard wired boards now. Fingers Crossed. Thanks again :D
Re: Ir Receiver
Don't forget the 47 ohm series resistors as well!.
