Please need help to Test Max797 Controller
whyman
Hi Novice here. I am Testing a Power Supply Board which consist at least 6 Max797 IC, Can Someone Please explain me how to test the Max797 IC Controller. Just want to make sure Max797 IC working fine. I downloaded Ref. PDF file but still not sure which pins should be tested.
Thank You
Thank You
What pins are you sure of?
Thank You for your interest. So far my understanding is that, Input Voltage supply to Pin# 10 (V+) and output voltage Pin#9 (CSL), Pin#11 (VL),. For ground There are Pin#4 (GND), Pin#12 (PGND). Then there is Pin#3 (REF) ?.
Thank You
