Connecting the two grounds together at the single point with a ferrite bead or surface mount chip can reduce the high-frequency ground digital noise getting into the analog ground.
No.According to the learnemc, making a ground separation (connection at one point) for the most cases is not a good idea
are you agree?
These are loaded questions and loaded statements and I think you're both talking about different things using the same words.No.
More than one connection point can cause a ground loop path for the digital ground noise current through the analog ground. You always want to control where the digital currents go to keep them away from the analog.
So you'll have to decide which suggestion seems better in your application.
