earckens
Currently my pool is equipped with a probe (plastic 2cm diameter, 8cm long) with 3 stainless steel 3mm hex bolts. Due to -I think- electrolysis -the pool uses salt water for chlorination- the lower of the 3 bolts has started corroding.
The probe senses 2 levels: low and normal.
The sensor is used for automatic pool water addition.
I have been looking for replacements -excluding floater or mechanical sensors-, from Pepperl&Fuchs (too expensive) to chinese clones.
1. ultrasonic sensors: probably the most versatile; hard/imossible to find in IP66 min. version (immersible) for reasonable cost (less then USD50)
2. capacitive sensors: insufficient range
3. optical sensors: risk of clogging the optics
4. pressure sensors: insufficient precision
5. alternative sensors: https://www.adafruit.com/products/463 , looks promising, but anyone any experience?
6. self-made: piece of plastic tube, 3cm diameter 10cm long, mount 3 hex bolts, attach 3 wires, seal everything with glue/tec/silicone/resin/..
Any ideas, suggestions?
The best idea that gets implemented receives to spend 2 days poolside![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
(southern France)
Erik
(southern France)
Erik
