Hi All
I hope you are doing well and not getting Corona.
I have an Invacare XPO2 portable oxygen concentrator
Mod. xpo100B, Ser # 11JF029132
I am getting a 3 & 4 light alarm and the machine shuts off. I am thinking that it is working but refuses to. There are no secondary code lights on so I assume it is a code 3000.
ERROR CODE Operating Alarm 3000
ALARM LEDs 3, 4
SUB-ALARM LED None
Operating Alarms: This alarm group centers on the sieve beds and the PSA process. These are alarms for which there is no corrective action available to either the patient or the provider. However, there are sub-codes that can be accessed to help the Invacare service and repair centers.
There is a 4 pin RS232 plug. I have isolated RX, TX & ground. When running, the other pin is 0 volts (35 ohms to ground. Logic low?) and 3.3 volts when off or flashing codes. I’m not sure how to get info.
Invacare XPO100 Service Manual
https://www.manualslib.com/manual/846360/Invacare-Xpo100.html
User manual https://www.manualslib.com/manual/78249/Invacare-Xpo100.html
The compressor works okay. It puffs pressure when you inhale.
The 2.5 Watt heaters all have 15v. & ground & 90 ohms.
21.5 on the hour meter.
New battery.
All repair companies but one refused to work on it. That one wanted $1000.00 minimum.
They say only the store that sold it can get it repaired. They are out of business.
I even tried varying the output voltage on what looks like an oxygen quality sensor.
I am hoping someone will have connections to tell me what a code 3000 means.
Otherwise, I may go “Steam punk” on it with an external compressor motor (that one is
15v. 3 phase) and an Arduino micro-controller for valves & heaters.
ALARM LEDs 3, 4
SUB-ALARM LED None
New battery.
