POST request ESP32 with SIM7000
JGLJGL
Hi, I'm new and not able to make a POSTt request.
I'm working with the arduino IDE and attached to the ESP32 a SIM7000E.
I 've tried the "SIM7000-LTE-Shield-master"->"ESP32_LTE_Demo" , but not being able to make it work (POST request).
Here it is what I have:
void loop() {
 Serial.print(F("FONA> "));
  while (! Serial.available() ) {
    if (fona.available()) {
      Serial.write(fona.read());
          // Post data to website
        uint16_t statuscode;
        int16_t length;
        char url[150];
        char data[150];
        flushSerial();
        Serial.println(F("NOTE: in beta! Use simple websites to post!"));
        Serial.println(F("URL to post (e.g. httpbin.org/post):"));
        Serial.print(F("http://")); readline(url, 79);
        Serial.println(url);
        Serial.println(F("Data to post (e.g. \"foo\" or \"{\"simple\":\"json\"}\"):"));
        readline(data, 79);
        Serial.println(data);
        Serial.println(F("****"));
        if (!fona.HTTP_POST_start(url, F("text/plain"), (uint8_t *) data, strlen(data), &statuscode, (uint16_t *)&length)) {
          Serial.println("Failed!");
        while (length > 0) {
          while (fona.available()) {
            char c = fona.read();
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
            loop_until_bit_is_set(UCSR0A, UDRE0); // Wait until data register empty.
            UDR0 = c;
#else
            Serial.write(c);
#endif
            length--;
            if (! length) break;
        Serial.println(F("\n****"));
        fona.HTTP_POST_end();
// flush input
  flushSerial();
Serial monitor response:
12:10:28.794 -> NOTE: in beta! Use simple websites to post!
12:10:28.794 -> URL to post (e.g. httpbin.org/post):
12:10:28.794 -> http://www.atesens.com/post
12:10:40.286 -> Data to post (e.g. "foo" or "{"simple":"json"}"):
12:10:43.242 -> password
12:10:43.242 -> ****
12:10:43.276 ->     ---> AT+HTTPTERM
12:10:43.311 ->     <--- OK
12:10:43.346 ->     ---> AT+HTTPINIT
12:10:43.381 ->     <--- OK
12:10:43.416 ->     ---> AT+HTTPPARA="CID"
12:10:43.449 ->     <--- OK
12:10:43.482 ->     ---> AT+HTTPPARA="UA"
12:10:43.515 ->     <--- OK
12:10:43.582 ->     ---> AT+HTTPPARA="URL"
12:10:43.615 ->     <--- OK
12:10:43.649 ->     ---> AT+HTTPPARA="REDIR"
12:10:43.682 ->     <--- OK
12:10:43.751 ->     ---> AT+HTTPSSL=1
12:10:43.785 ->     <--- ERROR
12:10:43.785 -> Failed!
I dont have any experience of sim7000.
However I have tried to use espressifs server library, I'm sure its perfectly fine but I had trouble uploading large datablocks with it, even with send_chunk.
Ok thanks, but is it posible to use it with Arduino IDE? As I have to use the Arduino IDE and the file is in .c, which I can open with Visual Studio.
It looks like that may be an HTTPS redirect?
If the code you are using does not support HTTPS it could be the problem.
Try a site that does not enforce https:// access ?
rjenkinsgb yes, I have tried with an http but also the same error.
Anyway, this is what the code shows, that's why I thought I could try with https:
  // Optionally configure HTTP gets to follow redirects over SSL.
  // Default is not to follow SSL redirects, however if you uncomment
  // the following line then redirects over SSL will be followed.
  fona.setHTTPSRedirect(true);
If I comment that line, this is the response, maybe I'm not sending the data in a proper way.
20:58:04.286 -> FONA> NOTE: in beta! Use simple websites to post!
20:59:47.631 -> URL to post (e.g. httpbin.org/post):
20:59:47.631 -> http://www.irun.org/post
20:59:54.691 -> Data to post (e.g. "foo" or "{"simple":"json"}"):
20:59:57.034 -> password
20:59:57.034 -> ****
20:59:57.081 ->     ---> AT+HTTPTERM
20:59:57.081 ->     <--- OK
20:59:57.128 ->     ---> AT+HTTPINIT
20:59:57.128 ->     <--- OK
20:59:57.200 ->     ---> AT+HTTPPARA="CID"
20:59:57.200 ->     <--- OK
20:59:57.269 ->     ---> AT+HTTPPARA="UA"
20:59:57.305 ->     <--- OK
20:59:57.351 ->     ---> AT+HTTPPARA="URL"
20:59:57.398 ->     <--- OK
20:59:57.445 ->     ---> AT+HTTPPARA="CONTENT"
20:59:57.492 ->     <--- OK
20:59:57.539 ->     ---> AT+HTTPDATA=8,10000
20:59:57.586 ->     <--- DOWNLOAD
21:00:07.556 ->     <---
21:00:07.556 -> Failed!
21:00:07.556 ->
21:00:07.556 -> ****
21:00:07.589 ->     ---> AT+HTTPTERM
21:00:08.076 ->     <--- OK
21:00:08.076 -> FONA>
However, here goes the whole code if it helps.
#include "Adafruit_FONA.h" // https://github.com/botletics/SIM7000-LTE-Shield/tree/master/Code
// Define *one* of the following lines:
//#define SIMCOM_2G // SIM800/808/900/908, etc.
//#define SIMCOM_3G // SIM5320A/E
#define SIMCOM_7000 // SIM7000A/C/E/G
//#define SIMCOM_7500 // SIM7500A/E
// For SIM7000 shield with ESP32
#define FONA_PWRKEY 18
#define FONA_RST 5
#define FONA_TX 16 // ESP32 hardware serial RX2 (GPIO16)
#define FONA_RX 17 // ESP32 hardware serial TX2 (GPIO17)
// For ESP32 hardware serial
#include <HardwareSerial.h>
HardwareSerial fonaSS(1);
// Use this for 2G modules
#ifdef SIMCOM_2G
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
// Use this one for 3G modules
#elif defined(SIMCOM_3G)
Adafruit_FONA_3G fona = Adafruit_FONA_3G(FONA_RST);
// Use this one for LTE CAT-M/NB-IoT modules (like SIM7000)
// Notice how we don't include the reset pin because it's reserved for emergencies on the LTE module!
#elif defined(SIMCOM_7000) || defined(SIMCOM_7500)
Adafruit_FONA_LTE fona = Adafruit_FONA_LTE();
#endif
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
uint8_t type;
char replybuffer[255]; // this is a large buffer for replies
char imei[16] = {0}; // MUST use a 16 character buffer for IMEI!
void setup() {
  //  while (!Serial);
  pinMode(FONA_RST, OUTPUT);
  digitalWrite(FONA_RST, HIGH); // Default state
  pinMode(FONA_PWRKEY, OUTPUT);
  // Turn on the module by pulsing PWRKEY low for a little bit
  // This amount of time depends on the specific module that's used
  powerOn(); // See function definition at the very end of the sketch
  Serial.begin(115200);
  Serial.println(F("ESP32 Basic Test"));
  Serial.println(F("Initializing....(May take several seconds)"));
  // Note: The SIM7000A baud rate seems to reset after being power cycled (SIMCom firmware thing)
  // SIM7000 takes about 3s to turn on but SIM7500 takes about 15s
  // Press reset button if the module is still turning on and the board doesn't find it.
  // When the module is on it should communicate right after pressing reset
  // Start at default SIM7000 shield baud rate
  fonaSS.begin(9600, SERIAL_8N1, FONA_TX, FONA_RX); // baud rate, protocol, ESP32 RX pin, ESP32 TX pin
  Serial.println(F("Configuring to 9600 baud"));
  fonaSS.println("AT+IPR=9600"); // Set baud rate
  delay(100); // Short pause to let the command run
  fonaSS.begin(9600, SERIAL_8N1, FONA_TX, FONA_RX); // Switch to 9600
  if (! fona.begin(fonaSS)) {
    Serial.println(F("Couldn't find FONA"));
    while (1); // Don't proceed if it couldn't find the device
  type = fona.type();
  Serial.println(F("FONA is OK"));
  Serial.print(F("Found "));
  switch (type) {
    case SIM800L:
      Serial.println(F("SIM800L")); break;
    case SIM800H:
      Serial.println(F("SIM800H")); break;
    case SIM808_V1:
      Serial.println(F("SIM808 (v1)")); break;
    case SIM808_V2:
      Serial.println(F("SIM808 (v2)")); break;
    case SIM5320A:
      Serial.println(F("SIM5320A (American)")); break;
    case SIM5320E:
      Serial.println(F("SIM5320E (European)")); break;
    case SIM7000A:
      Serial.println(F("SIM7000A (American)")); break;
    case SIM7000C:
      Serial.println(F("SIM7000C (Chinese)")); break;
    case SIM7000E:
      Serial.println(F("SIM7000E (European)")); break;
    case SIM7000G:
      Serial.println(F("SIM7000G (Global)")); break;
    case SIM7500A:
      Serial.println(F("SIM7500A (American)")); break;
    case SIM7500E:
      Serial.println(F("SIM7500E (European)")); break;
    default:
      Serial.println(F("???")); break;
  // Print module IMEI number.
  uint8_t imeiLen = fona.getIMEI(imei);
  if (imeiLen > 0) {
    Serial.print("Module IMEI: "); Serial.println(imei);
  // Set modem to full functionality
  fona.setFunctionality(1); // AT+CFUN=1
  // Configure a GPRS APN, username, and password.
  // You might need to do this to access your network's GPRS/data
  // network.  Contact your provider for the exact APN, username,
  // and password values.  Username and password are optional and
  // can be removed, but APN is required.
  fona.setNetworkSettings(F("orangeworld"), F("orange"), F(""));
  //fona.setNetworkSettings(F("m2m.com.attz")); // For AT&T IoT SIM card
  //fona.setNetworkSettings(F("telstra.internet")); // For Telstra (Australia) SIM card - CAT-M1 (Band 28)
 // fona.setNetworkSettings(F("hologram")); // For Hologram SIM card
void loop() {
        int16_t length;
        char url[80];
        char data[80];
        flushSerial();
        readline(data, 79);
            UDR0 = c;
#else
            Serial.write(c);
#endif
            length--;
// flush input
  flushSerial();
 void flushSerial() {
  while (Serial.available())
    Serial.read();
char readBlocking() {
  while (!Serial.available());
  return Serial.read();
uint16_t readnumber() {
  uint16_t x = 0;
  char c;
  while (! isdigit(c = readBlocking())) {
    //Serial.print(c);
  Serial.print(c);
  x = c - '0';
  while (isdigit(c = readBlocking())) {
    Serial.print(c);
    x *= 10;
    x += c - '0';
  return x;
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout) {
  uint16_t buffidx = 0;
  boolean timeoutvalid = true;
  if (timeout == 0) timeoutvalid = false;
  while (true) {
    if (buffidx > maxbuff) {
      //Serial.println(F("SPACE"));
      break;
    while (Serial.available()) {
      char c =  Serial.read();
      //Serial.print(c, HEX); Serial.print("#"); Serial.println(c);
      if (c == '\r') continue;
      if (c == 0xA) {
        if (buffidx == 0)   // the first 0x0A is ignored
          continue;
        timeout = 0;         // the second 0x0A is the end of the line
        break;
      buff[buffidx] = c;
      buffidx++;
    if (timeoutvalid && timeout == 0) {
      //Serial.println(F("TIMEOUT"));
      break;
    delay(1);
  buff[buffidx] = 0;  // null term
  return buffidx;
// Power on the module
void powerOn() {
  digitalWrite(FONA_PWRKEY, LOW);
  // See spec sheets for your particular module
#if defined(SIMCOM_2G)
  delay(1050);
  delay(180); // For SIM5320
  delay(100); // For SIM7000
#elif defined(SIMCOM_7500)
  delay(500); // For SIM7500
#endif
  digitalWrite(FONA_PWRKEY, HIGH);
Yes you can use it in arduino ide, I have, it comes in the esp32 core.
However you need to do some basic mods to make a .c file work, if thats what your working with.
