DerStrom8
Super Moderator
Hi guys!
First off, I'd like to thank EM for allowing me to post this here![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So, I've been thinking lately about opening an ebay store sort of thing, where I can sell some of the small projects that I design and make. At the moment I have a couple of projects that are just about ready to be sold as kits, but I would first like to know if it would be worth it. I was hoping you guys could give me a little feedback about my ideas to see if it's something that might draw some interest.
The first project is a secret knock detector, which is based on an arduino project I read about a while ago. However, instead of an arduino, this one would use a PIC on a pre-made PCB. The idea is that it mounts to a door with a deadbolt, and the user programs in a secret knock pattern of his or her choosing. From then on, until re-programmed, the device will unlock the deadbolt for anyone who gives the secret knock. It isn't designed to be a serious security device. It's just meant to be a fun little project, especially for beginners. It would come in a kit, including most of the important parts (resistors, capacitors, possibly the chip and motor as well), and if I decide to send the chip, it will be pre-programmed. It will come un-assembled, unless the customer requests it pre-assembled (at a slightly higher price). It will come with directions and the board layout diagram to make assembly easier.
The second project is a PIC-to-breadboard adapter, designed to save room on a breadboard and keep it neat for prototyping. The board will combine the ICSP connections and, perhaps, the 5 volt regulator circuit for the chip, and will line up the I/O ports in rows of headers, which plug into the breadboard. It will have a selectable program/run (so that MCLR can be used as an I/O if that is how the chip is designed). I currently have some designed for the PIC18F1330 (some other processors have the same pinout, such as the 1320), so that will work as well. If any interest is shown, I could easily design some for other PICs as well.
I'm thinking of making some other novelty-type boards, aimed especially for beginners and early hobbyists to practice with soldering and other board-assembly skills.
I am wondering if anyone here thinks this might be an endeavor worth following, and if you think there might be enough interest for it to be worth trying. I don't want to spend a few hundred dollars to make boards that nobody will buy
I'm just curious if anyone here has feedback, whether this may or may not be a reasonable project, and ways that I might be able to improve on the idea? I appreciate any suggestions you guys have ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Kind regards,
Der Strom
Kind regards,
Der Strom
