Hello All
My project is a trailer braking system for a car towed trailer. I want to control the trailer brakes from the brake pedal of the towing vehicle i.e. car or jeep). To do this i was thinking of using a linear potentiometer connected to the brake pedal, this would then send a signal to a linear actuator to control the master cylinder (piston that forces hydraulic fluid to wheel brakes). The further the piston moves the more pressure in the system thus a greater braking force.
The movement of the piston is controlled by the movement of the brake pedal
What i need to know if is, if it is possible to link a linear ( or rotary) potentiometer to a linear actuator ( servo or stepper)
(the position of the actuator is controlled by the position of the potentiometer)
Are the other methods to achieve this?
Looking forward to you thoughts,
Regards
Caff
Regards
Caff
