Hello, I have a 2 gang 10k audio taper pot. It is a mini pot - (blue with no online data) whatsoever! I measured the resistance between the pins on both (gangs?) The resistance varied from one to the other. Also there are no numbers on it and no online data to be found!
I assume that the ground goes to the ground sleeve on my stereo output jack? Does it also go to the board and ground? (I also assume it does?) , So from what I am able to find out is that a pot has pins 1, 2 , 3. 1 being the ground , 2 being the output - (wiper) to the output jack , and 3 coming from the output of the circuit feeding through the pot?
Please correct me or confirm me if i am correct! Thank you very much for your help!
The very bottom print is the one that I have built and cannot figure out how to connect the 10k pot/s to it! It is the one that is laid out in many different colors showing the capacitors-(yellow, red etc), pot, etc. at very bottom of that pdf page!
Here below is the link to the one that i have built and I cannot seem to get the pot to work properly!
https://www.electro-tech-online.com...tereo20Electret20Microphone20Preamplifier.pdf
Thank you very much in advance for your help!
