I try to do some modification to a PC wheel to use it on a XBOX.I did the steering part and the steering work, but i cant figure how to wire the pedal corectly. I need to get a range of 1.8k to 7.50 k from a 50k pot at the pedal. both pot the brake and the throttle are in parallel, that give a range from 9k to 25k (I cant reach the lower value the pedal rest at 9k).
The original Pot on the triggers was 10k each and connected in parallel, and all 3 pin of the pot was connected one is the ground,the middle the output that go in USB IC and the last one (the 5 v I think) go to the usb IC too. The value of the trigger was at ground and ouput : (open 7.5k , pressed:1.8k) and the output and the other (5v i think)
open 1.9k , pressed:7.4k). i already try to wire the steering like a variable resistor by wiring only the ground and the output and its turn only 1 side, and with all 3 wire its fine.
Its possible to get a range around 1.8 and 7.50k? from a 50k
If yes can someone make me a circuit with the value of the resistance and all the wiring .
forgive my english
forgive my english
