So my little project will be using LED's. I want to power about 6 LED's with a power pack.
this is the LED's I just ordered,
Source Material:InGaN !
Emitting Colour:5MM WHITE LED
LENS Type:Water clear
Color Temperature: --
Luminous Intensity-MCD: Typ: 35,000 mcd
Reverse Voltage:5.0 V
DC Forward Voltage: Typical:
DC Forward Current:20mA
Viewing Angle:25 degree
Lead Soldering Temp:260°C for 5 seconds
This is the battery I am thinking about getting:
Battery Specs:
6 Volt Rechargeable
4.5 Amp Hours
W-2.76" X D-1.89" X H- 4.25" -4" high not including the tabs
Weight- 1.85 lbs
Terminals - faston tab type
Interstate Model # SLA 0905
Will I be able to make this battery work reliably with the 6 LED's?
Thx
WF
Battery Specs:
6 Volt Rechargeable
4.5 Amp Hours
Weight- 1.85 lbs
Thx
WF
