Hello,
Please could you answer the following questions about the LT3799 PFC’d flyback LED driver?
LT3799 datasheet:
http://cds.linear.com/docs/en/datasheet/3799fa.pdf
Why is the current sense reference voltage just 100mV?
Other chips, such as LM3450, and all others, have at least half a volt for current sense reference voltage due to noise issues, why is the sense voltage so low for the LT3799?
Can the LT3799 be used with an opto-isolator as in the attached pdf schematic? (In this schematic, I have connected the internal error amplifer thats inside the LT3799, as a voltage follower. LTspice simulation of LT3799 based LED driver is attached, with the optocoupler feedback.
Why does the LT3799 have to use an internal multiplier block and why should it have to sense the input voltage? After all, the NCL30000 PFC flyback controller does not have either of these..
NCL30000 datasheet:-
http://www.onsemi.com/pub_link/Collateral/NCL30000-D.PDF
(the NCL30000 simply uses constant on time, which is all that is needed to give Power factor correction, when a Critical conduction mode flyback is used with virtually no primary bus capacitance.)
LTspice simulation of LT3799 based LED driver is attached also, with optocoupler feedback
LT3799 datasheet:
