hi atom,I will be sure to add a switch in the car to turn the device ON or OFF. This way it will cut the circuit completely. Ill be sure to use a 15v or 9v zenor and a nice 5w resistor. Should i use resistor on ground series or vcc? or it doesnt matteR?
It's not that important. I've got stuff running in my old car that has no protection at all and has run for years.
I did blow an ignitor by reverse connecting a battery once, though.
hi,WOW THANKS!!! i have some 1A diodes only tho. I guess i should get a 2A Diode... The fuse ill buy since its cheap also. Thanks GUYS!!! As for CAPS i have some 25v and 50v so im set!!! thanks
I second this. In truth, blowing the reg due to a spike is "unlikely". If you want something working in a few days, it's no problem at all. Well, 97% sure it won't blow within the first month.hi,
Long before the automotive regulators were on the market, I used the 78xx series of regulators in vehicles and boats with no problems.
Connect the battery to the 7805 via a 2amp diode and 2amp slow blow fuse.
Use a minimum of 25V rated 100nF ceramic & 100uF electrolytic on the input and output of the 7805.
You should use a regulator that is spec'ed for automotive use. Like an LM2931. These regulators have built in protection from reverse voltage and load dumps.
