transistance
The $40 is the DIY unit price!
Deal Extreme's entry level mounted LED is **broken link removed**
Yeah... it is an expensive choice which is what I meant. I will check out your link uber.
No spec's for the cheap Oriental LED. No Datasheet.Deal Extreme's entry level mounted LED is **broken link removed**
A comment on the Deal Extreme's website says they do not know anything about the LED except its voltage, colour, size and weight. Somebody tried to translate the spec's from the manufacturer but they do not make sense.
Buyer beware!
Lights in the floor?Any idea how this effect(or diffusion) created? Sand-blasted plexiglass maybe?
Well I missed this way back when...No spec's for the cheap Oriental LED. No Datasheet.
Buyer beware!
New one on me. That is the excat part number for an 80Lm white Rebel and when I ordered three some time ago that is exactly what I got.DealExtreme doesn't even know what color are their LEDs.
Maybe the colors are all mixed up and you get whatever color they have.
I don't know, I tried clicking on the links to the datasheets on the website but they seem to be broken. Do they have a contact number or email? Perhaps you should ask them.From the Turkish Osram Website but product description is in English:
OSRAM Dimmable ECG, as far as I understand this ECG is a package of instant starter + ballast capable of powering 2x24 W T5 which is exactly what I need. But does this work with a regular dimmer?
Yes normal dimmers are just phase controllers.How do the AC dimmers work btw? Are they basically phase controllers?
Dimmable ballasts do not do phase control, even if they are compatible with phase controllers. Dimmable ballasts normally work by either varying the duty cycle or the tube current.Do they somewhat control the duty cycle? or does the dimmable balast do the actual phase control? just wondering what part of the circuit does what...
To my knowledge there is only one company making that form factor. Rebels are then soldered directly to a metal core PCB.DealExtreme doesn't even use Luxeon Rebel part numbers so maybe they are a cheap Chinese imitation. There are many "manufacturers" of a Rebel Star. Lumileds makes only the tiny chip and other companies mount them on an aluminum heatsink. With chewing gum?
Question:
I have 1 power line going from my light switch to the ceiling (concrete building). How do I connect two (2x39W)dimmable e-ballasts and four 39W T5 FL to 1 power line? (any sketches would be awesome)
I understand the shunt for Amp,s, but couldn't a length of wire, or a resistor be substituted?
