Hi, I have a spa at home and made a solar heater with black tubing. I want to put a mini pump inline and hook direct to a solar panel i picked up cheap. I dont want to use a battery and eliminate buying a regulator for it.
Basically the idea is when their is sun it will heat the water in the pipe, also power the solar panel and make the pump run, when no sun ho heat, no power.
Could someone please point me in the direction for a circuit to run the pump.
Here are the specs.
Pump
12v Mini diaphragm pump
60w
Solar panel
Pmp 190w
imp 5,34a
vmp 35.61v
isc 5.52a
voc 44.28v
Thanks in advance![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here are the specs.
Pump
60w
Solar panel
Pmp 190w
imp 5,34a
vmp 35.61v
isc 5.52a
voc 44.28v
Thanks in advance
