Hi
Am new to the forum but reading over peoples posts everyone seems very helpful so i thought i would see if i could get in on the action.
I'm trying to design a contactless power monitor. Planning to use some sort of hall sensor clipped around the mains supply and then use this output to calculate the power being consumed.
I know i could buy one of these for fairly cheap but am trying to 'improve' ( more like get) an understanding of electronics more.
What I am thinking is that I can use a hall sensors ouput (an ac voltage representative to the current flowing through the wire?) and a pic to calculate the power.
I wasn't planning on taking a voltage reading as I assume that this doesn't fluctuate much around 230V (uk) so was just going to use this static value for the calculations.
Anyway my main query is what do i have to do with the ac signal from the hall to get it into the pic. I know i will need to convert it to DC and that some sort of rectification will be needed to do this.
I'm assuming that the currents i will be reading will about 80A and i want to measure fairy accurately from 0A-80A.
I have been looking around and have found a circuit that says it does something like this but i dont understand it much.
The first 2 sections look like(according to google searches) low pass filters and then some sort of rectifier and voltage follower. As for the other section and the 'float' voltages i have no idea whats going on.
Could anyone give me a clue as to why/what is being filtered and how the rectifier is working? Also any ideas as to other section would be greatly appreciated.
