hantto
To use these abilities does one only have to enable their bit when programming the PIC or is there some other that has to be done in the software?
If BOD is enabled then it's no idea to also enable POR because the BOD does the same?
To take advantage of the POR you have to tie the MCLR pin to V+ through a resistor (says the datasheet) is this also the case with BOD? If it is, what value would be satisfactory?
And one more. The power up timer. What purpose does it have? Yes it keeps the PIC reset an additional 72ms, for what? Is it enabled through the configuration bits only, or is there more to it? Does the PWRT apply to both POR and BOD?
Thanks for your time!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
