Michael Daly
I see a lot of power-on reset circuits with the same general layout. A resistor connects Vcc to a capacitor which then connects to ground. The point where the resistor and capacitor are connected is tapped to a Schmitt trigger and that output is the reset signal.
In order to ensure the capacitor is discharged quickly when a power drop happens, a diode is placed in parallel with the resistor.
Why is the diode in parallel with the resistor? It seems to my simple view that if the diode is parallel with the capacitor, it will discharge the capacitor when power is removed. If it's parallel to the resistor, when the power drops, it allows a low-resistance bypass of the resistor, but I don't see how that discharges the capacitor.
I'm obviously not an electronics expert but I know just enough to fiddle with digital circuits in "Lego" mode.
