power station related question
samina
1.Private generation: industrial co-generation, capacity generation.
2.Interconnected System: Capacity savings, power sharing amongst units for economic allocation
Can anyone help me understanding the above topics?
regards
samina
1. Private generation: Any electrical power generated apart from the power generated by publicly owned power companies (at least here in the USA).
Industrial co-generation: For example, power generated from the excess (or waste) heat of an industrial process that is then used to heat water to steam which is then used to power a electricity generating turbine.
Capacity generation: Total (or maximum) electrical power generation by generation type (private, in this case, if I'm following your question sequence correctly), generally subdivided by energy source.
2. Interconnected Systems: Capacity Savings. I'm not sure in what context this concept was discussed. Inter-connectivity amongst various power generating entities serves two purposes:
A. Back-up power availability during times of excess demand across (or between) usage areas and,
B. A reduction in the need for additional capacity within a single usage area. This results in a reduction in the costs of generation developmental costs within a particular usage area.
Lastly, "power sharing amongst units for economic allocation" sounds like governmental gobbledygook...:confused::confused:
