Power supply caps for 78L05.
3v0
Coop Build Coordinator
Forum Supporter
I am using a 78L05 (UA78L05ACLP). Looked for this info on that datasheet but am thinking it is expected that people reading it would already know. No there.
The test circuit is simple a .33uF cap on the input and a .1uF on the output. Simple enough.
Currently I have 1.0uF and .22uF electrolytic caps but no .33uF except for SMT 1210 ceramic parts. Would rather not use the SMT 1210s for this.
What impact would there be if I used the 1.0uF.
I am thinking none. Am I right that 3x is close enough?
Peeked at where he has a .1uF on the input side where the datasheet shows a .33uF for a LM7805CT regulator. Would that be better ?
The datasheet says that the input capacitor is not needed if the input pin is close to the filter capacitor, am I right?
330 nF capacitor is also not available in my college lab, I use 220 nF usually and it is working. Sometimes I don't even use the input capacitor, it is still working.
The caps are VERY important, especially the one on the output of the regulator. You "can" do without them sometimes, but the biggest reason they are there is to keep the regulator from oscillating internally. This results in very large ripple in the output voltage, and will contribute greatly to the heat output.
But this will not effect much if you draw very less current You can replace the output cap to 1uF.
And the input caps you can put .22uF or .22uF + .22uF = .44uF
3v0 said:
I did not see that in the ST Microdev or the TI datasheets.
You can see them in the national data sheet more details than ST or other manufactures.
Input caps for 7805 says they need if the power supply is more than 6 inches from the regulator,but 78L05 say it says it need .33uF if the power supply is more than 3 inches range.
Yes, the output capacitor is important especially when you use the regulated current to supply the microcontroller.
Its the electrolytic type of cap thats not suitable for high frequency decoupling required close to the regulator.
The ceramic, polyester, mylar or polyprop capacitors have a better higher frequency decoupling performance than electrolytic.
If you have spare tantalums in your scrap box, 0.1uF thru 4.7uF would be OK.
It's really a VERY non-critical value, I usually use small electrolytics (10uF or below) and have never had any problems. It's vital though that you have some sort of capacitors there, or it will oscillate, perhaps only under certain conditions.
