Gaston
could you guys take a look at this circuit and tell me if the five volt part will work. its a 24 volt center tap so i should get 12 volts from the center. and with only one diode i should only get helf of the wave which would be six volts or a little over 8 to the peak once the cap is charged.i hope to have enough to overcome the dropout of the regulator. could i get by with any lower valued capacitors on either side of the regulator? i just put 4700 because thats what i have. the five volts is for a isd1110p chip and thats all. does it look ok?
![POWER-SUPPLY.png POWER-SUPPLY.png](https://www.electro-tech-online.com/data/attachments/12/12399-ae347572a4b08d14e36235e75f70c312.jpg)
