hotrodhed120
Pic 16f870
4Mhz ats040 W/ 2-22mf 35v alum elec. capacitor (also tried W/ series res.)
5.3v input power
mclr tied to 5.3v (also tried with a 10m cap to ground)
Good grounds and power, no pins bent, built on a breadboard, all connections good
PortA not used (Tried connecting to ground)
PortB not used ( " " " " )
Portc inputs (7-4) - 4 normally open switches w/ 1k res. tied to ground
closed 5.3v
Portc outputs (3-0) - wired to 4 npn transistors controlling LEDS. (circuit works fine independently when applying 1.5v-5v to base.)
Sorry if the description is confusing I don't have a way to include a picture.
Programming with a picstart plus and mplab ide 7.5.
I've been trying to iron out all the details, finally got a good build with no errors and in the sim everything seems to work fine codewise, but when I burn the chip and put in the board , nothing happens
I HATE to burden you guys with a newbies problem, but this is the only place I have to ask someone who knows first hand how to build one of these little buggers from the ground up!
I've hooked my Genisys scanner/scope to the oscillator pins but I don't see any activity (don't really know what to look for this is the first time I've tried to diagnose/look at a xtal oscillator signal. The scope reads down to 5us and 200mv.)
I'm really not confident enough in my PICing to rule out a code problem either though so here it is. ANY help at all would be greatly apprieciated.
5.3v input power
closed 5.3v
list p=16f870 ; list directive to define processor
#include <p16f870.inc> ; processor specific variable definitions
__CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _XT_OSC & _WRT_ENABLE_OFF & _LVP_OFF & _CPD_OFF
;***** VARIABLE DEFINITIONS (examples)
; example of using Shared Uninitialized Data Section
INT_VAR UDATA_SHR 0x71
w_temp RES 1 ; variable used for context saving
status_temp RES 1 ; variable used for context saving
; example of using Uninitialized Data Section
TEMP_VAR UDATA_SHR 0x20 ; explicit address specified is not required
temp_count RES 1 ; temporary variable (example)
RESET_VECTOR CODE 0x000 ; processor reset vector
movlw high start ; load upper byte of 'start' label
movwf PCLATH ; initialize PCLATH
goto start ; go to beginning of program
INT_VECTOR CODE 0x04 ; interrupt vector location
movwf w_temp ; save off current W register contents
movf STATUS,w ; move status register into W register
movwf status_temp ; save off contents of STATUS register
; isr code can go here or be located as a call subroutine elsewhere
movf status_temp,w ; retrieve copy of STATUS register
movwf STATUS ; restore pre-isr STATUS register contents
swapf w_temp,f
swapf w_temp,w ; restore pre-isr W register contents
retfie ; return from interrupt
;VARIABLE REGISTERS=========================================================
SWTCHFLG EQU 0X20
COUNT EQU 0X21
clrf PCLATH ; ensure page bits are cleared
goto main ; go to beginning of program
main
bsf Status,5 ;move to bank 1
movlw b'11111111' ;select as input
movwf trisA ;
movlw b'11110000' ;
movwf trisC ;
movlw b'00000000' ;
movwf trisB ;
movlw B'11010111' ;PB PULLUPS DISABLE,INT ON RISING EDGE, INTERNAL INSTRUCTION CYCLE CLOCK, INCR. ON LOWTOHIGH TRANS.,PRSC.TMR0, PRSC. RATE SELECT BITS= 1:256
movwf OPTION_REG
bcf status,5 ;return to bank 0
clrf PORTA ;
CLRF PORTB ;
clrf PORTC ;
clrf INTCON ;DISABLE INTERRUPTS
CLRF SWTCHFLG
CLRF TMR0
CLRF COUNT
;POWER UP ROUTINE=====================
BCF STATUS,C
movlw B'00000001'
MOVWF PORTC
CALL DELAYP5
RLF PORTC
CALL DELAYP5
RLF PORTC
CALL DELAYP5
RLF PORTC
CALL DELAYP5
RRF PORTC
CALL DELAYP5
RRF PORTC
CALL DELAYP5
RRF PORTC
CALL DELAYP5
CLRF PORTC
MOVLW B'00001111'
MOVWF PORTC
CALL DELAYP5
CLRF PORTC
CALL DELAYP25
MOVLW B'00001111'
MOVWF PORTC
CALL DELAYP5
CLRF PORTC
CLRF TMR0
CLRF COUNT
CLRF W
GOTO START
;SUBROUTINES============================================================
;DELAY .25 SECOND
DELAYP25 CLRF TMR0
CLRF COUNT
MOVLW D'4'
MOVWF COUNT
RESETP25 MOVLW D'217'
MOVWF TMR0
LOOPP25 DECFSZ TMR0
GOTO LOOPP25
DECCNTP25 DECFSZ COUNT
GOTO RESETP25
RETURN
;DELAY .5 SECOND
DELAYP5 CLRF TMR0
CLRF COUNT
MOVLW D'9'
MOVWF COUNT
RESETP5 MOVLW D'217'
MOVWF TMR0
LOOPP5 DECFSZ TMR0
GOTO LOOPP5
DECCNTP5 DECFSZ COUNT
GOTO RESETP5
RETURN
START
btfsc PORTC,7
call SWTCHON0
btfsc PORTC,6
call SWTCHON1
btfsc PORTC,5
call SWTCHON2
btfsc PORTC,4
call SWTCHON3
GOTO START
SWTCHON0
call DELAYP25 ;give switch time to stop bouncing
btfss PORTC,7 ;check it's still pressed
RETURN
btfss PORTC,0 ;see if LED0 is already lit
CALL LED0ON
CALL LED0OFF
LED0ON
bsf PORTC,7 ;turn LED0 on
REL0A BTFSC PORTC,0
GOTO REL0A
GOTO START
LED0OFF
bcf PORTC,0 ;turn LED0 off
REL0B BTFSC PORTC,7
GOTO REL0B
GOTO START
SWTCHON1
btfss PORTC,6 ;check it's still pressed
RETURN
btfss PORTC,1 ;see if LED1 is already lit
CALL LED1ON
CALL LED1OFF
LED1ON
bsf PORTC,1 ;turn LED1 on
REL1A BTFSC PORTC,6
GOTO REL1A
GOTO START
LED1OFF
bcf PORTC,1 ;turn LED1 off
REL1B BTFSC PORTC,6
GOTO REL1B
GOTO START
SWTCHON2
btfss PORTC,5 ;check it's still pressed
RETURN
btfss PORTC,2 ;see if LED2 is already lit
CALL LED2ON
CALL LED2OFF
LED2ON
bsf PORTC,2 ;turn LED2 on
REL2A BTFSC PORTC,5
GOTO REL2A
GOTO START
LED2OFF
bcf PORTC,2 ;turn LED2 off
REL2B BTFSC PORTC,5
GOTO REL2B
GOTO START
SWTCHON3
btfss PORTC,3 ;check it's still pressed
RETURN
btfss PORTC,4 ;see if LED3 is already lit
CALL LED3ON
CALL LED3OFF
LED3ON
bsf PORTC,3 ;turn LED3 on
REL3A BTFSC PORTC,4
GOTO REL3A
GOTO START
LED3OFF
bcf PORTC,3 ;turn LED3 off
REL3B BTFSC PORTC,4
GOTO REL3B
GOTO START
END ; directive 'end of program'
