manz
does anybody know how does the circuit of the power window knows that the window is already fully opened or fully closed (cut-off switch). i`ve read how power windows work but just couldn`t really find the answer for it..
here`s the situation:
if u pressed (full) the button for the window to open, even after u release your fingger from the button,the window will still go down..
untill it reached its limit (fully opened), theres a sound (seem like a relay de-energize) and all the flow to the power window motor being cuts off.
the question is:
1. does anyone knows how the circuit can detect that the window had fully opened or fully closed??
2. is there a circuit that to measure the flow or voltage of a system(dc motor) that is to cut of the current supply if there`s too much load for the motor??
i`m so sure that there`s no mechanical switch used in the system. it is some sort of circuit that detact the current or something? is there any posibble way to do so (cut the current if there`s to much load for the dc-motor)
thanks guys...
the question is:
thanks guys...
