Hello good folks at electro-tech ![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have a small sub woofer which is connected to my computer and would like to now try it out in my car. (as you might have guessed, my car's audio system, well, that's being too generous, it's crap!)
I'd like to temporarily go with a cheap solution and install the sub woofer connected to my computer, in my car. I've had past experience with making normal desktop speakers run on batteries (hook up a 9V to the transformer output and it works like a charm. If you're interested in doing this, be sure to disconnect the transformer output wires before you hook up the 9v battery). I tried doing the same to my sub woofer but i got stuck when i saw the center tap from the transformer.
I've drawn a diagram showing the transformer output. Find it attached
How can i get power to my sub woofer from my car's 12v supply? Mind you that max power consumption is about 25W
I have thought of a DC/AC inverter, but a good one is too costly, and installing a proper sound system will put an even bigger hole in my pocket. Cant afford that at the moment.
Also, on a different matter, what program can i use to draw circuits and have them converted to strip board layout?
Thanks everyone and have nice day![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
