1. Can I use the below pre amp with a 12V single power supply?
2. How can I couple the below loudness circuit to above? Is it power amp volume or loudness volume?I see 4 pins in the volume..!!
It is a little hard to see in the picture but there is a 4th leg on this pot. I do not know where you can get them now days.2. How can I couple the below loudness circuit to above? Is it power amp volume or loudness volume?I see 4 pins in the volume..!!
Thanks everybody now I understood.It needs a special volume control.But l see some modern DIY pre amp boards has loudness switch but it has normal 3 pin volume controllers.
The amount of "loudness" boost needed depends on the sensitivity of the speakers and the amount of power produced by the amplifier. It will almost always have the wrong amount, don't use it.
Why are you using a ordinary TL082 opamps that might be noisy instead of using audio TL072 opamps that are selected and guaranteed to have low noise?
All half-decent audio products use low noise audio opamps. I have never seen a TL082 or a lousy old 741 opamp in anything.
I have used and designed audio products that used tens of thousands of TL07x opamps and none ever failed.
Here is a try to use a single supply. Note the input has a return of ground. The output is ac coupled and has the same return. The "1/2" point must have a large cap to the same return "ground". The 1/2 point does not need to be accurate.Can I use the below pre amp with a 12V single power supply?
Just what I was describing, with the important addition of the o/p cap, I forgot about that.
Ok thanks everybody.Thanks Ron for the adjustments.
I want more bass on low volume thats why I need a loudness switch.Now from your comments I think I'm unable to add one![]()
What about one of these?It is a little hard to see in the picture but there is a 4th leg on this pot. I do not know where you can get them now days.
The quality of the system is not the main factor in whether you have (or use) a loudness control.good quality equipment doesn't have a loudness control
The loudness control is to compensate for the ear frequency response versus sound intensity, not to correct for equipment deficiencies.
