preferred C compiler?
ManTic
Hey... I've been playing a bit with PIC16F877A and C, but with the compiler I use, i cannot send variables to the LCD...
The function i use looks like this:
void lcd_display(const char *buf)
	char i;
	i = 0;
	while(buf[i] != 0)
		wrdata(buf[i++]);
Where wrdata is:
void wrdata (char data)
// Write a Character to the LCD Display.
 { trisb = 0;
   portb = data;
   porte = LCD_DATA_WR;
   porte |= E_PIN_MASK;
   nop();
   porte &= ~E_PIN_MASK;
   lcd_wait();
And lcd_wait(), just waits for the busy flag to go down...
It works with constants.. of course - but it would be nice if I could write a variable to the LCD - results of calculations and stuff..
Which compiler?
SourceBoost C/C++ compiler, but I found a way around my problem, thanks anyway.
Its fairly easy to write a simple printf function to write to your LCD.
void xprintf(unsigned char* fmt, ...)
	va_list ap;				//Argument Pointer
	unsigned char* p;
	unsigned char Bval;
	unsigned int ival, temp;
	unsigned long lval;
	va_start(ap, fmt);
	p = fmt;
	while (*p)
		switch (*p)
			case '\n':
				EA = 0;
				putchar('\n');
				putchar(0x0D);
				EA = 1;
				break;
			case '%':
				p++;
				switch (*p)
					case 'x':
						ival = va_arg(ap,int);
						//if ((unsigned char) ival >> 8)
							EA = 0;
							PrintHex((unsigned char) (ival >> 8));
							EA = 1;
						EA = 0;
						PrintHex((unsigned char) ival);
						EA = 1;
						break;
					case 'd':
						ival = va_arg(ap, int);
						EA = 0;
						putint(ival);
						EA = 1;
						break;
					case 'l':
						lval = va_arg(ap, long);
						//if ((unsigned char) lval >> 24)
							EA = 0;
							PrintHex((unsigned char) (lval >> 24));
						//if ((unsigned char) lval >> 16)
							PrintHex((unsigned char) (lval >> 16));
						//if ((unsigned char) lval >> 8)
							PrintHex((unsigned char) (lval >> 8));
						PrintHex((unsigned char) lval);
						EA = 1;
						break;
					case '%':
						EA = 0;
						putchar('%');
						EA = 1;
						break;
			break;
			default:
				EA = 0;
				putchar(*p);
				EA = 1;
				break;
			p++;
	va_end(ap);
just replace all the putchars and printhexes with you LCD writing code
Brent
