Thanks Boncuk, but I'm going to tell you more for a more powerful answer. The application where the sensor is going to be used is as follows. It is a grinder for chicken wastes and as you see there will be blood, water .... I hope this could help...
So what kind of pressure is it? As I understand the device shreds chicken wastes, correct?
You're doing a horrible job of describing your problem.
That's because I still not having enough information about the process. I even have not seen it yet. It's operation was just described to me by a friend. What I'm asking about is the general parameters you will ask about when you are choosing a proper pressure sensor
Yes that is correct
So what are you trying to measure -- the force of the urge to vomit? You're doing a horrible job of describing your problem.
But there is no pressure involved in shredding. So what kind of pressure do you want to measure?
If It is Gas's you want to measure then a wheat stone bridge is what you need to build but it dos not measure pressure but Qty of gas to O2 present which you can then make the wheat stone bridge to control the application.
