1) I copied some codes from Nigel tutorial page onto the MPLAB code editor and I tried to run it but I keep getting an error complain from the assembler:
MPLINK 3.94, Linker
Copyright (c) 2005 Microchip Technology Inc.
Error - section 'INT_VECTOR' can not fit the absolute section. Section 'INT_VECTOR' start=0x00000004, length=0x00000010
Errors : 1
BUILD FAILED: Thu Jul 12 01:33:03 2001
2) According to the MPLAB tutorial, if I double click on the error the editor should take me to the line responsible for the error but that did not happen when I tried to build these codes.
Below is the code:
;Tutorial 1.1 - Nigel Goodwin 2002
LIST p=16F628 ;tell assembler what chip we are using
include "P16F628.inc" ;include the defaults for the chip
__config 0x3D18 ;sets the configuration settings (oscillator type etc.)
org 0x0000 ;org sets the origin, 0x0000 for the 16F628,
;this is where the program starts running
movlw 0x07
movwf CMCON ;turn comparators off (make it like a 16F84)
bsf STATUS, RP0 ;select bank 1
movlw b'00000000' ;set PortB all outputs
movwf TRISB
movwf TRISA ;set PortA all outputs
bcf STATUS, RP0 ;select bank 0
Loop
movlw 0xff
movwf PORTA ;set all bits on
movwf PORTB
nop ;the nop's make up the time taken by the goto
nop ;giving a square wave output
movlw 0x00
movwf PORTA
movwf PORTB ;set all bits off
goto Loop ;go back and do it again
end
MPLINK 3.94, Linker
Errors : 1
Below is the code:
movlw 0x07
movwf TRISB
Loop
movlw 0xff
movwf PORTB
movlw 0x00
movwf PORTA
end
