Hi
Problem I am trying to operate a GE spiral cfl via a remote, it is in a ceiling fan.
My hack works adding an extra load ie an in parallel 15 watt (smallest off the shelf) incandesent.
If you don`t it will only flash.
Spoke to Ge >>> tough luck >>>> speak to Clipsal their fixed dimmers work.
Spoke to Clipsal>>> we don`t have a remote that will work.
Would like to run two compact`s with a remote with out an incandesent light.
240v/50 .
I`m not that sure/gifted if it is too little load say 5 watts to get it started or the interfirence via the 50cycle...> to the remote> to cable parallel 5 feet> to the compac fluro.
Well I did test it with out the 5 feet same problem.
Help! thanks for listening
240v/50 .
