Problem in A Port of Pic and Programming
Hello. I am doing my mini project. I have Pic16f628a. It have two ports A & B.
What I am doing take input from A and give output at B. I have pulled up the A.
Ok. Upto this I had no problem. But while programing I had tested my pic in so many ways. Sometimes it gives flicker (Leds) on output pins. Doesn't take input from A.
So I tried just simple blinking of leds. It also sometimes blinks, sometimes not, When I bring my finger near to microcontroller Blinking stops. I have programed from different pickit2. On pcb circuit, on breadboard with three different Chips. Since I have three Pic16f628A. Also reinstalled Mplab and Hi tech c compilers. Checked power supply (with multimeter). Where I am doing mistake. PLZ HELP. :-(
We need two things...... Circuit and code..... Most pic16f628a problems are to do with the comparators one of your first commands needs to load the CMCON register with 7, then port A will be digital....
I got caught with that little trap myself just a couple of days ago!.:(
A hour or so of head scratching, why does this crazy port not work?:confused:
RTFM - the CMCON register - instant fix.:)
(Overdosing on smilies)
Thnks. I want to know why and how to do this..
What!
Do you have code and a circuit???? If you check the links in my signature... Nigel's tutorials are in ASM and I have recoded them into C.. All you need is there..
Thank u so much experts. ;) Solved my problem.
If any one having same problem or is beginner read-
cmcon=0x07
TRISA=0xff not "TRISA=1"
If (-----==1) "not" if (----=1)
Also have good connections of ICSP while programming. Don't use breadboard while u program a chip.
