Problem of converting to hex. Help Needed!!
pieter jamneck
Hi Guys,
I have build a POV wand and want to attach a dc motor to it. The problem I have is to change
the code so that RB0 is an input and waits for RB0 to go high before displaying the "message"
I did contact the auther of the code his advice:
"You may have changed the code in the wrong while loop. The one to change is at the very end of the code in the main() routine. The lines you need are already there, you just need to un-comment them.
while( 1 )
showMessage(message,address);
while(portb.0);
while(!portb.0);
delay_ms(7);
I have tried this, but did not want compile. I used Sourceboost( the auther's instuction), I am
not use to Sourceboost. So I think its human error from my side
Could somebody please help me to insert the extra instructions and complile to .hex ?
Kind Regards
Pieter
#include <system.h>
#include <eeprom.h>
//Target PIC16F628 configuration word
#pragma DATA _CONFIG, 0x3F18
//Set clock frequency
#pragma CLOCK_FREQ 4000000
unsigned char message[60];
unsigned char data;
unsigned char address;
rom char* A_seq = {0x7e,0x09,0x09,0x09,0x7e};
rom char* B_seq = {0x7f,0x49,0x49,0x49,0x3e};
rom char* C_seq = {0x3e,0x41,0x41,0x41,0x22};
rom char* D_seq = {0x7f,0x41,0x41,0x41,0x3e};
rom char* E_seq = {0x7f,0x49,0x49,0x49,0x41};
rom char* F_seq = {0x7f,0x09,0x09,0x09,0x01};
rom char* G_seq = {0x3e,0x41,0x41,0x49,0x7a};
rom char* H_seq = {0x7f,0x08,0x08,0x08,0x7f};
rom char* I_seq = {0x00,0x41,0x7f,0x41,0x00};
rom char* J_seq = {0x20,0x40,0x41,0x3f,0x01};
rom char* K_seq = {0x7f,0x08,0x14,0x22,0x41};
rom char* L_seq = {0x7f,0x40,0x40,0x40,0x40};
rom char* M_seq = {0x7f,0x02,0x04,0x02,0x7f};
rom char* N_seq = {0x7f,0x02,0x04,0x08,0x7f};
rom char* O_seq = {0x3e,0x41,0x41,0x41,0x3e};
rom char* P_seq = {0x7f,0x09,0x09,0x09,0x06};
rom char* Q_seq = {0x3e,0x41,0x51,0x21,0x5e};
rom char* R_seq = {0x7f,0x09,0x19,0x29,0x46};
rom char* S_seq = {0x46,0x49,0x49,0x49,0x31};
rom char* T_seq = {0x01,0x01,0x7f,0x01,0x01};
rom char* U_seq = {0x3f,0x40,0x40,0x40,0x3f};
rom char* V_seq = {0x1f,0x20,0x40,0x20,0x1f};
rom char* W_seq = {0x3f,0x40,0x38,0x40,0x3f};
rom char* X_seq = {0x63,0x14,0x08,0x14,0x63};
rom char* Y_seq = {0x03,0x04,0x78,0x04,0x03};
rom char* Z_seq = {0x61,0x51,0x49,0x45,0x43};
rom char* a_seq = {0x30,0x4a,0x4a,0x4a,0x7c}; //a
rom char* b_seq = {0x7f,0x50,0x48,0x48,0x30}; //b
rom char* c_seq = {0x38,0x44,0x44,0x44,0x20}; //c
rom char* d_seq = {0x38,0x44,0x44,0x48,0x7f}; //d
rom char* e_seq = {0x38,0x54,0x54,0x54,0x18}; //e
rom char* f_seq = {0x08,0x7e,0x09,0x01,0x02}; //f
rom char* g_seq = {0x06,0x49,0x49,0x49,0x3f}; //g
rom char* h_seq = {0x7f,0x08,0x04,0x04,0x78}; //h
rom char* i_seq = {0x00,0x44,0x7d,0x40,0x00}; //i
rom char* j_seq = {0x20,0x40,0x44,0x3d,0x00}; //j
rom char* k_seq = {0x7f,0x10,0x28,0x44,0x00}; //k
rom char* l_seq = {0x00,0x41,0x7f,0x40,0x00}; //l
rom char* m_seq = {0x7c,0x04,0x08,0x04,0x78}; //m
rom char* n_seq = {0x7c,0x08,0x04,0x04,0x78}; //n
rom char* o_seq = {0x38,0x44,0x44,0x44,0x38}; //o
rom char* p_seq = {0x7c,0x14,0x14,0x14,0x08}; //p
rom char* q_seq = {0x08,0x14,0x14,0x18,0x7c}; //q
rom char* r_seq = {0x7c,0x08,0x04,0x04,0x08}; //r
rom char* s_seq = {0x48,0x54,0x54,0x54,0x20}; //s
rom char* t_seq = {0x04,0x3f,0x44,0x40,0x20}; //t
rom char* u_seq = {0x3c,0x40,0x40,0x20,0x7c}; //u
rom char* v_seq = {0x1c,0x20,0x40,0x20,0x1c}; //v
rom char* w_seq = {0x3c,0x40,0x30,0x40,0x3c}; //w
rom char* x_seq = {0x44,0x28,0x10,0x28,0x44}; //x
rom char* y_seq = {0x0c,0x50,0x50,0x50,0x3c}; //y
rom char* z_seq = {0x44,0x64,0x54,0x4c,0x44}; //z
rom char* n0_seq = {0x3e,0x51,0x49,0x45,0x3e};
rom char* n1_seq = {0x00,0x42,0x7f,0x40,0x00};
rom char* n2_seq = {0x42,0x61,0x51,0x49,0x46};
rom char* n3_seq = {0x22,0x41,0x49,0x49,0x36};
rom char* n4_seq = {0x18,0x14,0x12,0x7f,0x10};
rom char* n5_seq = {0x27,0x45,0x45,0x45,0x39};
rom char* n6_seq = {0x3e,0x49,0x49,0x49,0x30};
rom char* n7_seq = {0x01,0x71,0x09,0x05,0x03};
rom char* n8_seq = {0x36,0x49,0x49,0x49,0x36};
rom char* n9_seq = {0x06,0x49,0x49,0x29,0x1e};
rom char* exp_seq = { 0x00,0x0,0x5f,0x0,0x0};
rom char* colon_seq= { 0x00,0x36,0x36,0x0,0x0};
rom char* space_seq ={ 0,0,0,0,0 };
rom char* heart_seq = {0x0c,0x1e,0x3c,0x1e,0x0c};
rom char* asterisk_seq = {0x2a,0x1c,0x7f,0x1c,0x2a};
bit oldVal;
int idx;
rom char *GetByteList(char c)
switch(c)
case 1: return A_seq;
case 2: return B_seq;
case 3: return C_seq;
case 4: return D_seq;
case 5: return E_seq;
case 6: return F_seq;
case 7: return G_seq;
case 8: return H_seq;
case 9: return I_seq;
case 10: return J_seq;
case 11: return K_seq;
case 12: return L_seq;
case 13: return M_seq;
case 14: return N_seq;
case 15: return O_seq;
case 16: return P_seq;
case 17: return Q_seq;
case 18: return R_seq;
case 19: return S_seq;
case 20: return T_seq;
case 21: return U_seq;
case 22: return V_seq;
case 23: return W_seq;
case 24: return X_seq;
case 25: return Y_seq;
case 26: return Z_seq;
case 33: return a_seq;
case 34: return b_seq;
case 35: return c_seq;
case 36: return d_seq;
case 37: return e_seq;
case 38: return f_seq;
case 39: return g_seq;
case 40: return h_seq;
case 41: return i_seq;
case 42: return j_seq;
case 43: return k_seq;
case 44: return l_seq;
case 45: return m_seq;
case 46: return n_seq;
case 47: return o_seq;
case 48: return p_seq;
case 49: return q_seq;
case 50: return r_seq;
case 51: return s_seq;
case 52: return t_seq;
case 53: return u_seq;
case 54: return v_seq;
case 55: return w_seq;
case 56: return x_seq;
case 57: return y_seq;
case 58: return z_seq;
case 59: return n0_seq;
case 60: return n1_seq;
case 61: return n2_seq;
case 62: return n3_seq;
case 63: return n4_seq;
case 64: return n5_seq;
case 65: return n6_seq;
case 66: return n7_seq;
case 67: return n8_seq;
case 68: return n9_seq;
case 69: return exp_seq;
case 70: return colon_seq;
case 71: return heart_seq;
case 72: return asterisk_seq;
// Everything else is a space
return space_seq;
void showData(const char data)
if(data & 0b0000001) clear_bit(portb,3); else set_bit(portb,3);
if(data & 0b0000010) clear_bit(porta,7); else set_bit(porta,7);
if(data & 0b0000100) clear_bit(porta,6); else set_bit(porta,6);
if(data & 0b0001000) clear_bit(portb,7); else set_bit(portb,7);
if(data & 0b0010000) clear_bit(portb,6); else set_bit(portb,6);
if(data & 0b0100000) clear_bit(portb,5); else set_bit(portb,5);
if(data & 0b1000000) clear_bit(portb,4); else set_bit(portb,4);
void showMessage(const char *message, char count)
char i;
char j;
char data;
rom char *sequence;
for(j=0; j<count; j++)
sequence = GetByteList(message[j]);
for(i=0; i<5; i++)
// Display column
data = sequence;
showData(data);
delay_us(200);
delay_us(200);
// All Off
portb = 0xff;
porta = 0xff;
delay_us(200);
delay_us(200);
// Space between letters.
delay_ms(1);
void programming()
unsigned char data = 1;
unsigned char i,j;
unsigned char count;
for(i=0; i<3;i++)
for(j=0;j<7;j++)
showData(data);
data <<= 1;
data |= 1;
delay_ms(45);
for(j=0;j<7;j++)
data >>= 1;
showData(data);
delay_ms(45);
while(!portb.1 || !portb.2); // Wait for both buttons to be released
data = eeprom_read(address);
showData(data);
while(1)
count = 10;
while(!portb.1 && count)
delay_ms(2);
count--;
if(count == 0) // Held down for 20ms?
data++;
if(data>0x7f) data = 0;
showData(data);
count = 80;
while(!portb.1)
delay_ms(15);
if(count) count--;
if(count==0)
data++;
if(data>73) data=0;
showData(data);
if(data==0 || data==16 || data ==32 || data==48 || data==64)
while(!portb.1);
if(!portb.2) // Button 2 is pressed
delay_ms(10);
if(!portb.2) // Is it still pressed?
eeprom_write(address++,data);
showData(data);
while(!portb.2); // Wait for release
void main( void )
cmcon = 7; //disable comparators
clear_bit( option_reg, 7 );
//Configure port A
trisa = 0x00;
//Configure port B
trisb = 0x07; // RB0, 1, 2 are inputs.
//Initialize port A
porta = 0x00;
//Initialize port B
portb = 0x00;
delay_ms(100);
address = 0;
while((data = eeprom_read(address)) != 0)
message[address++] = data;
if(!portb.1 || !portb.2)
address = 0;
programming();
else
//Endless loop
while( 1 )
//while(portb.0);
//while(!portb.0);
delay_ms(7);
Two things:
Better to post this in the Microcontroller forum.
Learn how to use the # code tags to post code.
