Problem trying to send several bytes using I2C, TM4C123 biard
JavierMA
Hi all,
I am asking for your help because I am trying to send several bytes using the I2C protocol in a program wich makes use of 2 I2C modules, and looks that it gets stuck after sending the first byte when checking the BUSY bit in I2CMCS. The board I am programming is the TM4C123GH6PM.
Here is the block diagram:
And here is the diagram available in the board's Data Sheet:
And this is the code in charge of sending the array content:
C:
int touch_lcd_write(enum typeOfWrite type, char command_data[], short I2C, int len)
            //Some code not related with the problem
            i=0;
            while(I2C1_MCS_R&I2C_MCS_BUSBSY);
            I2C1_MSA_R =write_touch_addr; //Specify the slave address of the master and that the next operation is a Transmit
            I2C1_MDR_R=command_data;    // Register address
            I2C1_MCS_R=0x03;    // (START, RUN).
            while(I2C1_MCS_R&I2C_MCS_BUSY != 0); //here gets stucked
            //Check if an error happens
            if(I2C1_MCS_R&I2C_MCS_ERROR)    //Check the ERROR bit in the I2CMCS register to confirm the transmit was acknowledged.
                //Send stop
                I2C1_MCS_R=0x04;
                if(I2C1_MCS_R&I2C_MCS_ARBLST)
                    return 1;
                else
                    return 2;
            i++;
            while(i<len)
                if(i==len-1)
                    //Last byte. Generate RUN and STOP
                    I2C1_MCS_R=0x05; //RUN,STOP
                else
                    //Generate RUN as it is not the last byte
                    I2C1_MCS_R=0x01; //RUN
                while(I2C1_MCS_R&I2C_MCS_BUSY != 0);   //Wait until the transmiI2Con completes by polling the I2CMCS register's BUSBstart_Y bit until it has been cleared.
                        //Send stop
                        I2C1_MCS_R=0x04;
                            return 1;
                        else
                            return 2;
                i++;
If I am not wrong, I am correctly following the diagram, but I can't see what is going wrong, so any help is appreciated.
Thanks,
Javier
Hi Mike,
Thanks for asking, that reminds me I forgot to add that information to my first post. About your question, I can tell that the lines for both I2C connections have pullup resistors with the correct values as they came integrated with the touch display I bought.
Regards,
Javier
Assuming all the hardware is correct then I would suggest using a different master/slave to see at which end the problem is. Do you have something that you can use as a know good master? Even an Arduino will do. Also, the I2C bus can become unresponsive if a transmission is interrupted which can happen when a ner compile is initiated.
Yes, I can use an Arduino Uno. Anyway, I just found the error and it is kind of funny. I have the I2C device connected through prototype cables and a very small PCB with a ZIF to SMD connector and by chance I pressed a cable end and it just started to work.
Here is the code with the comments edited just in case anyone reading it is interested:
C:
            i=0;
            while(I2C1_MCS_R&I2C_MCS_IDLE != 0x20);
                I2C1_MCS_R=0x04;   //Send STOP
                    return 1;
                else
                    return 2;
            i++;
            while(i<len)
                if(i==len-1)
                else
                    //Generate RUN as it is not the last byte to be sent
                    I2C1_MCS_R=0x01;
                while(I2C1_MCS_R&I2C_MCS_BUSY != 0);   //Wait until the transmission completes by polling the I2CMCS register's BUSY bit.
                        return 1;
                    else
                        return 2;
                i++;
