Hi all,
first post here. I am trying to design a simple voltage follower in breadboard using TL082cp opamp and the circuit is attached. However i am getting very noisy output even though the simulator worked fine.
I have connected everything as in the picture with only the ground connection is missing(did not use any ground connection) and connected the ground probe of osciloscope to the negative supply. Is there anything that i did wrong here??
Thnak You
Thnak You
