I've used one of the pic delay calculators to generate a delay of 10 seconds. If I use this in a simple led blink routine it works. I'm now using using it in my program however and am having problems.
What the program does is the following:
I"m using RB0 interrupt to increment a counter every time its triggered. In the main program whenever the counter reaches 10, I pulse a LED. This bit works 100%
Where the problem now comes in, is in my main loop of the program every 10 seconds I want to blink another led (eventually this will be replaced with a serial output routine)
The problem is this 10 second led is never pulsed. Am I missing something obvious?
The problem is probably somewhere around the carryon label, but for the life of me I can't figure it out.
LIST p=16F628 ;tell assembler what chip we are using
include "P16F628.inc" ;include the defaults for the chip
__CONFIG 0x3F34
; Variables
cblock 0x20 ;start of general purpose registers
count1 ;used in delay routine
count2 ;used in delay routine
count4
count5 ;used in delay routine
count6 ;used in delay routine
count7
TEMP ; temp variable for w register
flash_count ; number of flashes
endc
org 0x0000 ;org sets the origin, 0x0000 for the 16F628,
;this is where the program starts running
goto start
; Interrupt
org 0004h ; interrupt routine
movwf TEMP ; store value of w in temp
incf flash_count,1 ; increment flash count
bsf PORTB, 2 ;turn on RB7 only!
call Delay100ms ;this waits for a while!
bcf PORTB, 2 ;turn off RB7 only!.
bcf INTCON, INTF ; clear interrupt flag
movfw TEMP ; restore value of w
retfie ; end of routine
; Main
start
; setup RB0 as a interrupt
bsf INTCON,GIE ; GIE - global interrupt enable
bsf INTCON,INTE ; INTE - RB0 - interrupt enable
movlw 0x07
movwf CMCON ;turn comparators off (make it like a 16F84
bsf STATUS, RP0 ;select bank 1
movlw b'00000001'
movwf TRISB ; set RB0 as input
movlw b'00010000';
movwf TRISA ;set first 4 pins on PortA as outputs
bcf STATUS, RP0 ;select bank 0
clrf PORTA
clrf PORTB ;set all outputs low
;setup variables for 10 sec loop
movlw 0x5a
movwf count4
movlw 0xcd
movwf count5
movlw 0x16
movwf count6
Loop
; when count = 10 pulse LED
movlw 0x0a
subwf flash_count,0
btfss STATUS,0
goto carryon
bsf PORTB, 1
call Delay100ms
bcf PORTB, 1
clrf flash_count
carryon
decfsz count4,1
goto $+2
decfsz count5,1
goto $+2
decfsz count6,1
goto Loop
;10 secs reached
bsf PORTB, 3 ; pulse 10 second timer led
call Delay100ms
bcf PORTB,3
goto Loop ;go back and do it again
;Delay 100ms
Delay100ms
;199993 cycles
movlw 0x3E
movwf count1
movlw 0x9D
movwf count2
Delay100ms_0
decfsz count1, f
goto $+2
decfsz count2, f
goto Delay100ms_0
return
end
