problem with jdm programmer using ic-prog
mikelim
hi there,
please help me with this.
i got this kit from silicon chip dse -sep2003.
i built this pic programmer - jdm programmer which it should be.
the pic programmer should be functionable because it met up with the several specified testpoints, so i supposed that it is working.
the problem should lies with the io driver installed in my laptop.
i had a usb to serial port convertor.
i installed the port io driver and the ic-prog as advised.
the problem is that i can use the hardware check to test the programmer (using the mclr and the data out met with in the data in ticks.)
BUT i cant do the above using the mentioned hardware check using io direct mode.
although, it is allowable, the ic-prog progesses as per normal to write / erase e.g. BUT it does behave as it should.
please help asap.
thanks.
