Problem with PIC code
SumitRanjan
I have recently burn a pic 16f690. But the chip is not giving desirable output. It is not not for any I/P and giving garbage value like a counter. But it should take I/P and give O/P according to I/P.
I think the problem is in the given part of the code below. I am using 4MHz oscillator and 22pf booster. If anybody can help I will be really thankful to him.
#include<pic.h>
#define _XTAL_FREQ 4000000 //4MHz Crystal
__CONFIG (INTIO & WDTDIS & PWRTEN & MCLREN & UNPROTECT & UNPROTECT & BORDIS & IESODIS & FCMDIS); "
If you are using an external crystal then your config needs state XT oscillator. However, I doubt that is your problem and, as Ian says, you need to post your code.
Oh Yeah... Missed that... However that usually causes the pic not to run atall, I've never tried to run a pic like that so it'll be guesswork
Thanks guys. Here is my code
#include<pic.h>
#include<pic.h>
#include<htc.h>
#define votting_time 3000
int BNP,AL,JP,GJM,HI;
display(int x)
int y,z;
y=x/10;
z=x%10;
PORTC=(y<<4)+z;
int main()
ANSEL=0;
ANSELH=0;
TRISA=0b111111;
TRISB4=1;
TRISB5=1;
TRISB6=1;
TRISB7=1;
TRISC=0b00000000; //PORTC As Output Port
PORTC=0;
while(1)
BNP=eeprom_read(1);
AL=eeprom_read(2);
JP=eeprom_read(3);
GJM=eeprom_read(4);
HI=0;
if(RB4==1)
if(RA0==0)
BNP++;
eeprom_write(1,BNP);
display(BNP+AL+JP+GJM+HI); // display data to 7segment
__delay_ms(votting_time);
else if(RA1==0)
AL++;
eeprom_write(2,AL);
else if(RA2==0)
JP++;
eeprom_write(3,JP);
else if(RB7==0)
GJM++;
eeprom_write(4,GJM);
else if(RA3==0)
HI++;
eeprom_write(5,HI);
if(RB4==0)
if(RA0==0)
display(eeprom_read(1)); // display data to 7segment
else if(RA1==0)
display(eeprom_read(2)); // display data to 7segment
else if(RA2==0)
display(eeprom_read(3)); // display data to 7segment
else if(RB7==0)
display(eeprom_read(4)); // display data to 7segment
else if(RA3==0)
display(eeprom_read(5)); // display data to 7segment
__delay_ms(2000); // 2 sec dealy
if(RB6==0)
if(eeprom_read(1)>eeprom_read(2))
if(eeprom_read(1)>eeprom_read(3))
if(eeprom_read(1)>eeprom_read(4))
if(eeprom_read(1)>eeprom_read(5))
display(1);
__delay_ms(3000);
else display(5);
else if(eeprom_read(4)>eeprom_read(5))
display(4);
__delay_ms(3000);
else display(5);
__delay_ms(3000);
else if(eeprom_read(3)>eeprom_read(4))
if(eeprom_read(3)>eeprom_read(5))
display(3);
__delay_ms(3000);
else display(5);
__delay_ms(3000);
display(4);
__delay_ms(3000);
else display(5);
__delay_ms(3000);
else if(eeprom_read(2)>eeprom_read(3))
if(eeprom_read(2)>eeprom_read(4))
if(eeprom_read(2)>eeprom_read(5))
display(2);
__delay_ms(3000);
else display(5);
__delay_ms(3000);
display(4);
__delay_ms(3000);
else display(5);
__delay_ms(3000);
display(3);
__delay_ms(3000);
else display(5);
__delay_ms(3000);
else display(5);
__delay_ms(3000);
if(RB5==0)
BNP=0;
AL=0;
JP=0;
GJM=0;
HI=0;
eeprom_write(1,BNP); // Erase Data AL
eeprom_write(2,AL); // Erase Data AL
eeprom_write(3,JP); // Erase Data AL
eeprom_write(4,GJM); // Erase Data AL
eeprom_write(5,HI); // Erase Data AL
display(0); // display data to 7segment
return 0;
