sanddune008
Hi All,
Prj Description:
I am designing a hub which receives i/p's(max of 4 inputs) from actuators and slaves connected to the hub(output). When an actuator input is received Master(Hub) will process it and sends a common command to all the salves connected to its output....based on the command each slave will do the necessary.
Now the problem is the slave receives data which is contains noise and hence displays junk day to the LCD........
Can anyone please verify my schematics.....which is attached.
Also attached is my slave input(yellow w/form) and master output(blue w/form)......
Thanks in advance...........
Prj Description:
