Hello All,
I just bought a simple circuit design software (TINA basic) and drew a simple 555 circuit which I want to use for a new project. The first circuit I made (bistable) is supposed to lock the output in the high/low position if you temporarily touch Trigger/Reset to ground. I try testing the circuit with a virtual Multimeter and it doesn't lock at all--the output stays in the low position unless I'm touching the trigger to ground (push momentary 1 in attached diagram). As soon as I let the trigger go high (stop pushing momentary 1) the output (pin3) goes to back to low position.
I thought the software must be wrong, so I made the same circuit on a breadboard and it does exactly the same thing!
Am I missing something? This seems like it should be very easy.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Any thoughts?
Thank you very much.
Any thoughts?
