Problems with an initial start on an LCD library using MPLAB xc8...
si2030
Hi there
I am in the process of building an LCD library that I can use in other projects. The idea is to have most variables in a header file and all the functions in a C file. the problem is, it will not compile even when I strip out most of the functions. I don't understand why and I think it might have something to do with the #includes at the start of each file.
I am in the habit of over documenting my files as I do not program regularly enough to remember why I have done what I have done when I revisit the code in one or more years time.
All I have is an LCD initialisation function and it refuses to compile.
I have included all three files (the third is a test file once it has enough functions written to run it)
I am hoping someone might have a look and see (hopefully a rookie mistake) and let me know.
Kind Regards
Simon
  • LCD_Header.h
  • LCD_Functions.c
  • LCD_TEST.c
It won't compile as you haven't finished the library..
You are using LCD Busy() and LCDCommand() and others, but you haven't written them!!!
Also to use __delay_ms() you need to define the crystal frequency.... # define _XTAL_FREQ '[frequency]'
"Also to use __delay_ms() you need to define the crystal frequency.... # define _XTAL_FREQ '[frequency]'"
What compiler error does this give Ian? If you don't use the #define
i think we have one answer why LG's code isn't working ;),
he has the #include but osc frequency defined. if i keep him off the laptop for the day, then i can look smart for 24 hours :D
