spondootre
I've been learning the basics of PIC programming using assembly language and have had no problems, then today while trying to debug a bit of code I tried to write to a 16F818 chip with my Velleman P8048 board and ProgPic2 2.6.0. It failed to write and then subsequaently when I tried to write or erase from the chip I got the message :
I thought I may of just had a faulty chip, so stuck another in and the same happenned, So I picked another chip and changed the code again, re-compiled and wrote to it no problem.
Can the ICs be broken by incorrect code? Are these ICs now useless or is there something I can try to erase them?
Incidentaly the board is in PGM mode, and the pic type isn't mismatched with the software, the board (which has test LEDs on) runs through the program sequence with no problems.
Malc
Malc
