parts-man73
This little bit of code I wrote as a practice while teaching myself assembly. I programmed the PIC, with options for watchdog off, and using the internal oscillator, and put in a solderless breadboard. I connected 8 LEDS with current limiting resistors on RB0-RB7. VSS is connected to ground, VDD connected to 5V, and pin 4 pulled to 5V with a 4.7k resistor.
I expected to see a "bit" to scroll across the LED's, then start again from the other side. and continue until the cows come home.
What I get is a few of the LEDS in the first nibble light up in order, then nothing out of the second nibble, and nothing repeats.
Is this a code error that I'm overlooking? Sorry about the formatting in the code, I guess a subquestion is, how are people attaching code so it looks nice?
Thank you,
Brian
INCLUDE "P16F628A.inc"
COUNT1 equ 20h
COUNT2 equ 21h
bsf STATUS,RP0 ;bank 1
clrf TRISB
bcf STATUS,RP0 ;bank 0
Start CLRF PORTB
movlw 01h ; load 00000001 in W
movwf PORTB ; then move w to portb
Loop call Delay ; delay routine
rrf PORTB,1 ; rotate bits right
goto Loop
Delay
Loop1 decfsz COUNT1,1
goto Loop1
decfsz COUNT2,1
goto Loop1
return
end
Thank you,
Brian
COUNT1 equ 20h
COUNT2 equ 21h
clrf TRISB
Start CLRF PORTB
goto Loop
Delay
goto Loop1
decfsz COUNT2,1
goto Loop1
return
end
