Programmer Problem
inktomi
Hi, I'm getting into PIC programming, so I built Bob Blick's Tait Style programmer to program a 16F84A chip. I tried to use IC-PROG but I'm getting verify error at 0000h (code protection is off).
I used the hardware check and measured all the voltages without the PIC and everything seems OK. The MCLR pin has a voltage of 13.1V when on. I then inserted the PIC and measured the voltages again, however the RB6 and RB7 pins are at 2.2V when high. Is this normal? To my understanding of the way the circuit is designed, the voltage on the RB6, RB7 pins will be the voltage set by the potential divider: ie. pull up and input resistance of the PIC pin.
Also, the parallel cable I'm using is about 1m long. Is this an issue with Bob's circuit or should I cut it or terminate it properly?
Thank you
