Programming in MikroC
PhilipWarence
Off Topic Bros. Sorry but I had been frustrating since last night that i cant figure this simple goal out...
void main()
PORTB = 0;
TRISB = 0;
for( PORTB=0; PORTB<=7; PORTB++)
Delay_ms(50) ;
Hello guys, Sorry to disturb yah'll. Im a beginner in MikroC. I had just started using this last night. Can i ask what's wrong with my code? My goal is to HIGH all the pins in portb 1 by 1 in PIC16F877A using a loop. But the only thing that happened is only pin RB0 turns high. Help guys. Thank you a lot..
Hi PhilipWarence , I have moved your post to its own thread. Next time please start your own instead of hijacking someone else's ;)
Welcome to ETO, and good luck!
Regards,
Matt
When PORTB is configured as analog, it always read as 0, so PORTB++ always sets it to 1. It's a good idea to use LATB instead.
If you want to do what you descrbed, do:
C:
TRISB=0; LATB = 1;
while(1) {
  LATB = (LATB<<1)+1;
  // appropriate delay here
There is no LATB on a 16 series chip. Try adding ADCON1=0x06; at the beginning of your code.
You need to shift PORTB to light each in turn.
Try this
C:
void main()
   char x;
   PORTB =1;
   TRISB = 0;
   for( x=0; x <8; x++)
      Delay_ms(250) ;
      PORTB<<=1;
Or this to light each one after each other..
C:
void main()
   char x;
   PORTB =1;
   TRISB = 0;
      Delay_ms(250) ;
      PORTB<<=1;
      PORTB+=1;
Or in binary
C:
void main()
   char x;
   PORTB =1;
   TRISB = 0;
   for( x=0; x <256; x++)
      Delay_ms(50) ;
      PORTB = x;
Either case its better to use a buffer!!
Ian's code should work well (didn't realize you were trying to light each in turn). However, the ADC still needs turning off.
