amady said:Can or not i'm using 12 volt instead 13 volt during burning to the IC
gogo2520 said:DIY Electronics KIT81 calls for 18 volts dc or 13 volts ac
to operate yes.. but he was talking about programming the part..HANDzCLEANx said:gogo2520 said:DIY Electronics KIT81 calls for 18 volts dc or 13 volts ac
DIYK81 requires 14+ volts(dc).......but the PIC16F84A only requires 5v(dc) to operate.......
amady said:Thank all my friend... i was use my laptop and it work with RCD programmer... my laptop supply 10V and can be use for burning...
Nigel Goodwin said:amady said:Thank all my friend... i was use my laptop and it work with RCD programmer... my laptop supply 10V and can be use for burning...
Don't forget, it's providing plus and minus 10V, giving a total of 20V, 10V isn't enough to program a PIC.
williB said:it worked !!?? :shock: 8) 8)
williB said:congradulations..!!
It's really cool when it does what you programmed it to do..
What next?
williB said:Nigel has a great site with lots of interresting stuff on there..
amady said:williB said:Nigel has a great site with lots of interresting stuff on there..
Thanks...
Nigel was use 16F628... but i'm using 16F84A... so how i want to modified the program (.asm)... ?? :?:
The differences are very slight, there's a couple of lines included to make the 16F628 more like an 84 - these are commented and should be removed for an 84, you should also alter the header and config settings.
But the main problem is the lack of I/O pins on an 84, far better to use it's modern replacement (the 628) rather than the obselete 84 - particularly as the 628 is considerably cheaper.
amady said:The differences are very slight, there's a couple of lines included to make the 16F628 more like an 84 - these are commented and should be removed for an 84, you should also alter the header and config settings.
Actually now i'm try to modified your .asm file... then the cct also.. when i'm finished all this thing i will publish on web with your permission...
yes i believe they are the same in that respectThat the 16F84A need external ossicalator like RC...??? What about 16F628??
