I'm now just over a year into construction of a AUV/ R/C Sub hybrid. I've been working on the electronics for a while now, and have started to hit some brick walls. I've figured it was probably best to start a thread that post here and there.
Current progress can be seen on my site: **broken link removed** I'm hoping to have the hull,propulsion, ballast system and essential electronics woking by end of April time.
The problem I'm faced with at the moment:
The main batteries are 6 6V 162Ah sealed deep cycle lead acid all wired in series to give me the 36V I need for the main drive motor. I'd like to be able to monitor the voltage across each battery however I've no idea how to go about this.
I was thinking a 'heavy duty' (high voltage?) opamp using as a diff amp with wires coming from the postive and negative terminals of each battery.....Am I on the right track here or is there something I'm missing?
The problem I have is that it's not reletive to zero volts.....
Can any one help me please?
I started elec. lessons sept last year, but we've spent far too long (for my liking
) on logic gates/systems....
Cheers,
Michael
Cheers,
Michael
