Hi everyone.
- A 10x probe is meant to isolate the circuit from the scope as much as posible (using pasive probes), but the problem is the impedance mismatch (a 50 ohm termination at the scope input is not enough).
- A 1x probe is not 50 ohm, and has low bandwitdh.
- so it seems that a simple 50 ohm coax + ohm termination at the scope input is the way to go.
But, 1/10x probes are used to avoid using a simple coax in the first place (due to parasitic capacitance, for instance). So, when using a regular coax+50ohm termination to probe RF, those drawbacks are there.
So, what is the best way to probe RF?
